Text Area alignment change
How to change the alignment of textarea from the default style set in touchgfx designer?
In touchgfx designer(Version:4.21.3) I have set to Left alignment. I use this textarea for multiple purposes, for few I need to set to Left alignment and for few I need to set to Right alignment. I tried using ' textArea.setTextAlignment(TEXT_ALIGNMENT_RIGHT);' but it says set alignment is not a member.
