STemWin and mbed os
Bkim.6
i use disco-f429zi.
Is it possible to stemwin from mbed os?
I tried to use the STemwin library STemWin_CM4_wc16.a file provided by the cube fw_f4 firmware pack, but the code process stopped at GUI_Init().
The development environment is keil uvision5. Is it possible to use STemWin library files in mbed os?
Imen.D
Hello @Bkim.6​
Have you enabled CRC?
The CRC must be enabled before calling GUI_Init, if not STemWin will be not function.
This is mentioned in the page 6 of AN4323 to call GUI_Init function prior to use any STemWin function or GUI routines:
"The CRC module (in RCC peripheral clock enable register) should be enabled before using the library."
 Maybe this post helped you: Using stemwin library - Mbed OS - Arm Mbed OS support forum
When your question is answered, please close this topic by choosing Select as Best.
Imen
Imen
Bkim.6
yes, i enable CRC
in my main.c
main() {
   uint16_t          x, y;
    uint8_t           text[30];
    uint8_t           status;
    TIM_HandleTypeDef TimHandle;
    uint32_t          uwPrescalerValue = 0;
    HAL_Init();
    BSP_SDRAM_Init();
    __HAL_RCC_CRC_CLK_ENABLE();
    SystemClock_Config();
GUI_Init()
return 0;
still freeze at GUI_Init()
