PixelDataWidget Application note: I want to display camera data on LCD using Touchgfx library.
Uc.2361
Hello Everyone,
I am new to this Touchgfx 4.12.3 c++ library and FreeRTOS environment.
I am working on a project which need to grab the camera data from DCMI peripheral and display on the LCD. I have done it in bare metal and I have no issue but I am switching my complete project into Touchgfx freertos environment.
I researched alot on the procedure, but there is no proper example how to use this pixel data widget? or DynamicBitMap widget?.
I have checked the following links regarding the same but no help:
I am able to display and image created in touchgfx designer tool.
I am able to directly display the camera data on the LCD by writing to the buffer directly without using widget but i am unable to show image at that particular time and the video hangs up after sometime.
Note: Tools and micro controller used:
STM32f746IG, TouchGFX 4.12.3 Designer tool, IAR embedded workbench.
External SDRAM is used as the Buffer.
Thanks in Advance,
Upender
Uc.2361
Hello TouchGFX Team,
Can any one help on the above posted Issue.
