Mixed image on screen
MHaji.1
Senior
I have a custom board with STM32H743 and working on a project by TouchGFX 4.24. When the device power on or reset, some times I have a mixed image including numbers, pictures and ..., which I attached the image... and some times every thing is Ok after reset or power on. I have another project by TouchGFX on this board, which it always works fine.
Please help me with this, thanks.
13 REPLIES 13
I don't get what's your mean by make diff, The projects are different...
Start by checking the MPU configuration.
It's not obvious to tell you what is the problem. As you have a working project, you need to check what is the difference between your working and non-working projects.
PS: Be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
I have been checking 2 project together but no special differences I have found, Could importing GUI to this project be related to the problem?
It's hard to tell...  You can start the project from scratch and proceed step by step and try to find when the behavior occurs to locate the issue.
