method for getting RGB values of touchpoint
GMair
is there a method to get the RGB value of the touchpoint of the display?
And if not how would a workaround look like?
Thanks and Best regards
Gerd
Osman SOYKURT
Hello GMair,
This question has been asked and a solution was suggested in this thread.
Hope it helps :)
/Osman
Osman SOYKURT
3 REPLIES 3
MM..1
Chief III
I mean not from TGFX. It only renders objects in sequence. After rendered is pixel unknown.
You need read it from framebuffer directly.
Osman SOYKURT
Hello GMair,
Hope it helps :)
/Osman
Osman SOYKURT
GMair
Hello Osman, MM..1
thank you guys for the info.
BR
Gerd
