method for getting RGB values of touchpoint
‎2023-04-06 6:24 AM
is there a method to get the RGB value of the touchpoint of the display?
And if not how would a workaround look like?
Thanks and Best regards
Gerd
TouchGFX
‎2023-04-11 2:52 AM
‎2023-04-06 10:51 AM
I mean not from TGFX. It only renders objects in sequence. After rendered is pixel unknown.
You need read it from framebuffer directly.
‎2023-04-11 2:52 AM
‎2023-04-13 5:49 AM
Hello Osman, MM..1
thank you guys for the info.
BR
Gerd
