2020-06-12 11:02 AM
Even though the error message in the Designer indicates that an image file name can begin with an underscore, the TouchGFX Designer is complaining about it:
This might be something you may want to look into.
2020-06-15 12:23 AM
You're absolutely right; Thanks for the heads up. I just bonked a guy from the designer team on the head and made him create a ticket for it - The validation is not correct, as you stated, because images starting with underscore should be completely fine.
/Martin
2020-06-15 12:23 AM
/Martin
