Image defect
‎2020-02-15 8:44 AM
‎2020-02-17 8:57 PM
I disabled ChromeART (DMA2D) in CubeMX options - artifacts disappeared.
Tell me, what's may be wrong with ChromeART (DMA2D) ???? How to fix?
‎2020-02-17 9:01 PM
Here is my DMA2D options
‎2020-02-18 11:49 AM
Anybody help me!!!
‎2020-04-10 2:15 PM
I have the same problem. Moreover, once out of ten when loading these strips do not occur, and then the entire interface works normally. I use STM32F769 Disco + STM32CubeIDE + TouchGFX 4.13. At first I thought the board was defective and bought another one. The result is the same.
‎2020-04-30 3:18 AM
The DMA2D configuration will be "overwritten" by the TouchGFX HAL when doing DMA2D transfers because it knows the pixel formats of whats coming in and whats going out. I haven't seen this issue but i'll try your concrete project.
‎2020-04-30 3:18 AM
It's not there anymore - If you're still having issues, could you re-upload? thanks
‎2020-10-15 7:45 AM
Hello Martin,
was the cause of this vertical line artifacts ever found? I am having the same issue with Hardware is similar to STM32f764-Disco, Cube IDE 1.4.2, Touch Designer 1.13.0.
Thank you,
‎2020-10-16 1:20 AM
Have you tried downloading the latest version of TouchGFX Designer 4.15 ?
/Romain
‎2020-10-16 7:25 AM
Thank you for your fast response!
I have TouchGFX Generator 4.13, 4.14, and 4.15 listed under software packages in CubeIDE. However when I open the .touchgfx file from inside the IDE TouchGFX Designer 4.13 opens. Could this be the issue? It is possible that the IDE and/or the TouchGFX generator were updated since the initial project was created.
What is the best way to bring all software packages up to the proper version without breaking the project?
‎2020-11-16 5:17 AM
I'm also having issues with stripes. Using CubeIDE V1.4.2 CubeMX V6.0.1 and TouchGFX Designer V4.15.0
Any help is appreciated.
- « Previous
- 1
- 2
- Next »
