Image defect
EEuge
Senior
Look at the project
and look at the display
You can see artefacts.
Why?
19 REPLIES 19
EEuge
Senior
Hm.... I can delete vertical lines near pictures if I use 32-bit SDRAM as 16-bit (I reconfigured FMC). But I want to use all 32 bit. Is it bug of your library?
And stripes on circle still present, even in 16 bit mode....
EEuge
Senior
Stripes on circle disappeared, if I use RGB565...
But I want RGB888.
How?
Romain DIELEMAN
Just to be sure, could we see your code? It might be due to some missing invalidated widgets. If not, some more details on your project would be useful to have a better insight of this issue. Thanks,
/Romain
Thanks!​
I will upload code in the evening, since 7 hour after this post.
Look at this topic later, please.​
Martin KJELDSEN
Chief III
Please provide more details on which MCU you're working with, how you created the project, etc.
/Martin
Stm32f746be, ​MT48LC4M32B2P-6A
Project created with cumbeMX 5.5 and last version of touchgfxdesigner.
I'll upload project here later.​
EEuge
Senior
YESS!
Half of problem solved!!!!!
CubeMX hasn't automatically generated MPU_Config for SDRAM! It generated it only for qSPI (address 0x90000000)
I added this code
void MPU_Config(void)
  MPU_Region_InitTypeDef MPU_InitStruct = {0};
  /* Disables the MPU */
  HAL_MPU_Disable();
  /** Initializes and configures the Region and the memory to be protected
  MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  MPU_InitStruct.BaseAddress = 0xD0000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_16MB;
  MPU_InitStruct.SubRegionDisable = 0x0;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
  MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
  HAL_MPU_ConfigRegion(&MPU_InitStruct);
  MPU_InitStruct.Number = MPU_REGION_NUMBER1;
  MPU_InitStruct.Size = MPU_REGION_SIZE_2MB;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER2;
  MPU_InitStruct.BaseAddress = 0xD0200000;
  MPU_InitStruct.Number = MPU_REGION_NUMBER3;
  MPU_InitStruct.BaseAddress = 0x90000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_256MB;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER4;
  MPU_InitStruct.AccessPermission = MPU_REGION_PRIV_RO;
  /* Enables the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
And stripes on circle disappears! And other widgets looks very well.
But stripes near widgets still present.
Look to the code, that i posted (MPU_Config) May be something still wrong?
