I inquire about TouchGFX Compile error.
2022-06-21 4:54 PM
hello
To call a specific function by including discovery.h in Model.cpp
A compile error occurs.
However, in CubeIDE, it compiles normally and runs well.
I want to know why a compile error occurs in TouchGFX and a normal compile in CubeIDE.
1.The development environment is as follows
- STM32H725g-dk
- CubleIDE 1.9.0
- TouchGFX 4.19.1
2. The source of model.cpp is as follows.
#ifndef SIMULATOR
extern "C" {
#include "stm32H7xx.h"
#include "stm32h735g_discovery.h"
#endif
void Model::tick()
#ifndef SIMULATOR
int button_sample = BSP_PB_GetState(BUTTONn); //BUTTONn // BUTTON_USER
if (button_sample != 0x000F)
if( buttonState != button_sample )
modelListener->PUI_data(button_sample);
buttonState = button_sample;
else
3.The error message in TouchGFX is as follows.
Compile
make -f ../gcc/Makefile -j8
Reading TouchGFX/application.config
Compiling TouchGFX/gui/src/scrtopcook_screen/ScrTopCookView.cpp
Compiling TouchGFX/gui/src/scrtopcook_screen/ScrTopCookPresenter.cpp
Compiling TouchGFX/generated/gui_generated/src/scrbottom_screen/ScrBottomViewBase.cpp
Compiling TouchGFX/generated/gui_generated/src/scrtopcook_screen/ScrTopCookViewBase.cpp
Compiling TouchGFX/generated/gui_generated/src/scrtopset_screen/ScrTopSetViewBase.cpp
Compiling TouchGFX/generated/gui_generated/src/scrauto_screen/ScrAutoViewBase.cpp
Compiling TouchGFX/generated/gui_generated/src/scrmain_screen/ScrMainViewBase.cpp
Compiling TouchGFX/generated/gui_generated/src/common/FrontendApplicationBase.cpp
Compiling TouchGFX/generated/gui_generated/src/scrtop_screen/ScrTopViewBase.cpp
Compiling TouchGFX/generated/gui_generated/src/scrloading_screen/ScrLoadingViewBase.cpp
Compiling TouchGFX/generated/images/src/image_Pause.cpp
Compiling TouchGFX/generated/images/src/BitmapDatabase.cpp
Compiling TouchGFX/generated/images/src/image_restart.cpp
Compiling TouchGFX/target/generated/TouchGFXGeneratedHAL.cpp
Compiling TouchGFX/target/generated/TouchGFXConfiguration.cpp
Linking TouchGFX/build/bin/target.elf
TouchGFX/build/STM32H735G-DK/TouchGFX/gui/src/model/Model.o: In function `Model::tick()':
c:\TouchGFXProjects\Noble_cooker/TouchGFX/gui/src/model/Model.cpp:29: undefined reference to `BSP_PB_GetState'
collect2.exe: error: ld returned 1 exit status
gcc/Makefile:293: recipe for target 'TouchGFX/build/bin/target.elf' failed
make[2]: *** [TouchGFX/build/bin/target.elf] Error 1
gcc/Makefile:289: recipe for target 'generate_assets' failed
make[1]: *** [generate_assets] Error 2
../gcc/Makefile:49: recipe for target 'all' failed
make: *** [all] Error 2
STM32H7 series
TouchGFX
2022-06-21 9:50 PM
TouchGFX use different makefile as CUBE. You need add search path to added headers and add source files into TGFX makefile.
2022-06-21 10:10 PM
thank you for your reply.
I don't know how to modify the makefile in TouchGFX.
Are there any guides provided?
2022-06-22 1:40 AM
@MM..1 but the posted error is not about problems finding a header file?
2022-06-22 1:47 AM
@mSH.1 "To call a specific function by including discovery.h in Model.cpp A compile error occurs. However, in CubeIDE, it compiles normally and runs well."
So the TouchGFX build is C++ - is the CubeIDE build also C++, or just plain C ?
This doesn't look right:
#ifndef SIMULATOR
extern "C" {
#endif
#ifdef __cplusplus
extern "C"
#endif
#ifdef __cplusplus
#endif
@mSH.1
2022-06-22 2:29 AM
hello @Andrew Neil
Thanks for the useful feature.
As I was informed, the moel.cpp part was modified as follows.
#ifdef __cplusplus
extern "C"
#endif
#ifdef __cplusplus
#endif
But the same error occurs.
It occurs only in touchGFX and compiles normally in CubeIDE.
Run Simulator
Generate
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
Reading ./application.config
Done
Post Generate
touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
Done
Post Generate Target
.project files generated inside project folder
This is STM32CubeIDE project updater: Working on ../STM32CubeIDE/.project
.cproject file: ../STM32CubeIDE/.cproject
Float ABI: hard
Writing STM32CubeIDE project file: ../STM32CubeIDE/.project
Writing STM32CubeIDE project file: ../STM32CubeIDE/.cproject
Done
Compile
make -f simulator/gcc/Makefile -j8
Compiling gui/src/scrbottom_screen/ScrBottomView.cpp
Compiling gui/src/scrbottom_screen/ScrBottomPresenter.cpp
Compiling gui/src/scrtopcook_screen/ScrTopCookView.cpp
Compiling gui/src/scrtopcook_screen/ScrTopCookPresenter.cpp
Compiling gui/src/containers/CustomContainer_temp_wheel.cpp
Compiling gui/src/scrtopset_screen/ScrTopSetPresenter.cpp
Compiling gui/src/scrtopset_screen/ScrTopSetView.cpp
Compiling gui/src/model/Model.cpp
gui/src/model/Model.cpp:18:10: fatal error: stm32H7xx.h: No such file or directory
compilation terminated.
generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/model/Model.o' failed
make[2]: *** [build/MINGW32_NT-6.2/gui/src/model/Model.o] Error 1
make[2]: *** Waiting for unfinished jobs....
generated/simulator/gcc/Makefile:155: recipe for target 'generate_assets' failed
simulator/gcc/Makefile:32: recipe for target 'all' failed
Failed
Failed
2022-06-22 2:59 AM
@mSH.1 "As I was informed, the moel.cpp part was modified as follows"
I don't know the context of that snippet, so don't know if it's actually what you wanted - but certainly the original didn't look right.
There may be other places in your code with similar issues?
Do you understand the issues of mixing C and C++, and why/when the extern "C" is required?
You are now getting errors due to not finding header files - so, as @MM..1 said, you do need to adjust your include paths...
2022-06-22 7:17 AM
In TouchGFX you need reconfigure build command to use Cube headless build. If you need this click...
