I have taken over a project from a colleague. When I run "Run Simulator" or "Run Target" I get the error message: ld.exe: cannot find -ltouchgfx What could be the reason for this error?
Roger.ch
libraries not visible to the project, check lib paths and where it is trying to fetch them from, and if they are there.
C​reate a new project, have that build successfully, and review how that's constructed.
6 REPLIES 6
Yoann KLEIN
Hello @Roger.ch​ ,
Did you already try to uninstall and reinstall TouchGFX ?
Otherwise, please also follow the introduction guidelines. There is maybe something in the installation procedure which might help you solve your issue.
Thanks,
/Yoann
Yoann KLEIN
Javier1
Principal
good luck @Roger.ch​ , it looks like your colleage left some barbed wire behind for the next guy
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
Hi Yoann.
Thank you for your submission.
I have uninstalled versions 4.18 and 4.20 and reinstalled very strictly according to instructions.
Unfortunately without much success.
Where should this "module" be installed and where are the entries so that the ID.exe can find them?
Greetings, Roger
Can you share your project here please ?
/Yoann
Yoann KLEIN
Thank you very much for your comment. The project is now running.
Sometimes you can't see the forest for the trees.
When comparing a new project I noticed that the directory ".....\Project\Middlewares\ST\TouchGFX\touchgfx\lib\core\cortex_m7\gcc" was extremely empty.
I then simply copied the folder from a self-generated custom project. And what can I say, it works.
Many thanks to all involved.
