I think ther is a bug on touchGFX 4.20.0
If you choose the object "static graph"
Insert in "Y-axis Range Min" = 60
Insert in "X-axis Range Min" = 0
Insert in "X-axis Range Max" = 8
Then click into the box Y-axis Min (where you have insert 60), now the value into the X Max it changes by itself in 60.0001 and is impossible to change this value.
This is a big problem for us because our develop is stopped.
Mario
