Error when debugging: Failed to execute MI command
‎2025-03-31 12:20 PM
I have a project that ran without issue, with STM32CubeIDE 1.13.0. When I updated it to 1.17.0 I could no longer debug that same project. The error window says:
Error in final launch sequence:
Failed to execute MI command:
load D:\\Proyectos\\STM32CubeIDE\\XXXX\\XXXX\\Debug\\XXXX.elf
Error message from debugger back end:
Error finishing flash operation
I added the log file in case it helps
- Labels:
STM32CubeIDE
‎2025-04-01 7:08 AM - edited ‎2025-04-01 7:10 AM
Pffft - not elf (but debug launch- maybe.).
I try in such "strange" cases: use the other debug ! (and watch for every possible error or warning message !!!)
So ST/GDB -> open OCD , set generator options ! (to same...software reset, etc.), then try...
i had sometimes very starnge effects : suddenly debug no more working...switch to OCD , not working...switch back to using GDB - hey works again ! So try...play a little bit around.
‎2025-03-31 1:02 PM
Maybe st-link needs update first...did you try ?
connect using CubeProgrammer , and show, what its telling. (set connect: normal, software reset)
‎2025-03-31 1:17 PM
Thanks for the reply
Yes, I forgot to add that I also updated the STLINK-V3 firmware
I used CubeProgrammer and had no errors:
‎2025-03-31 1:54 PM - edited ‎2025-03-31 1:54 PM
Good,
so it should work in IDE also. Just set same ...(set connect: normal, software reset)
because obvious: st-link and your cpu ok, can connect. So just the settings in IDE could ... be not so good.
‎2025-04-01 5:31 AM
I just did it, but it shows the same error. Could it be an error in the .elf or launch files after updating?
‎2025-04-01 7:36 AM
I couldn't make it work with GDB, but it debugs successfully with OCD
I can use it as is, but I'll try to make it work with GDB if it can be fixed
Many thanks AScha!
