How to add Preprocessor definition to TouchGFX Designer?
Marco.R
Hi @Martin KJELDSEN​
Is it possible to add a preprocessor definition​ to the TouchGFX Designer? In Visual Studio it is very easy, but when I try to run the application in the designer it fails. How can I add a Preprocessor definition to the Designer (like SIMULATOR).
Marco
Martin KJELDSEN
Chief III
Hi Marco,
Sure, The designer uses Makefiles and gcc. Concretely, the makefiles use the config located in config/gcc/app.mk:
# Optional additional compiler flags
user_cflags := -DMYFLAG=2
/Martin
4 REPLIES 4
Martin KJELDSEN
Chief III
Hi Marco,
/Martin
Marco.R
​Perfect. Thank you
Welcome! :)
SMour.1
Actually that solution is not that perfect because once in a while you have to suffer the auto generation on this file.
Are there any alternatives?
