How can i save the data entered from keyboard on flash memory?
BGünç.1
I want to save the text entered from keyboard (widget) . How can i do that? Or how can i access the address of the text entered from keyboard? Could someone help me?
3 REPLIES 3
MM..1
Chief II
Save to use after poweroff, or save for actual runtime?
Firstly, thanks for the response. After poweroff. I save the text in a box. Then, after i entered the text and after poweroff, i want to still be there.
Then you need solve 3 steps in your code.
  1. learn and implement EEPROM emulation techniques and software for STM32 Microcontrollers - Application note
  2. before poweroff store text to eeprom space
  3. after poweron load back in screen or main setup stage
Maybe you dont need emulation , when your MCU have internal EEPROM or you use an external...
