2021-11-21 11:23 PM
2021-11-22 6:54 AM
If you're talking about a position and color that will never change, it's done by TouchGFX designer itself.
If you're talking about a dynamic change, in your <screen>View.cpp
Normally you call:
<yourtext>.setPosition(<X position>, <Y position>, <width>, <heigth>);
<yourtext>.setColor(touchgfx::Color::getColorFromRGB(<R value>, <G value>, <B value>)); or <yourtext>.setColor(touchgfx::Color::getColorFrom24BitRGB(<R value>, <G value>, <B value>));
<yourtext>.invalidate();
2021-11-22 10:47 PM
thanks for replay , but i talk about standard keyboard custom container , i found it i can change it in ( keyboardLayout.hpp ) file .
in this structure :
static const Keyboard::Layout layout =
BITMAP_KEYBOARD_BACKGROUND_ID,
keyArray,
30,
callbackAreas,
3,
Rect(10, 10,781, 312), ////baraye toghiyire makane khoruji
TypedText(T_ENTEREDTEXT),
#if !defined(USE_BPP) || USE_BPP==16
0x215249, ///// baraye taghire range khoroji
#elif USE_BPP==24
0xFFFFFF,
#elif USE_BPP==8
0xFF,
#elif USE_BPP==4
0xF,
#elif USE_BPP==2
0x3,
#else
#error Unknown USE_BPP
#endif
Typography::KEYBOARD,
0
