Unable to execute my own application without TrustZone on STM32U5 (B-U585I-IOT02A) after executing SBSFU application example
2022-08-05 2:02 PM
I ran the SBSFU example of STM32CubeU5 following what is in the readme file without any problem. Then I disabled TrustZone but I cannot run the projects made with STM32CubeIDE, verification of the downloaded firmware fails. If I try to erase the flash memory (full chip erase) with STM32CubeProgrammer I get an error message. The error message indicates to check the flash memory protection but I have not set some flash memory protection.
2022-08-10 2:26 PM
Hi @Mohamed Aymen HZAMI,
I solved the problem by running the regression.bat commands that disable memory protection and erase the memory completely.
2022-08-10 2:57 AM
Hello @Domenico and welcome to the community,
Can you please share a snapshot with the error message?
Mohamed Aymen
2022-08-10 2:26 PM
2022-08-10 4:14 PM
Hi Domenico,
SBSFU requires TrustZone to be enabled in order to boot in a secure zone (root of trust).
The settings is described in Readme of SBSFU project, section 2. Initialize the device
- Please ensure with STM32CubeProgammer the following Option bytes configuration for the device:
- RDP = 0xAA (RDP Level 0)
- DBANK = 1 (Dual bank mode enabled)
- SWAP_BANK = 0 (Bank1 and Bank2 are not swapped)
- nSWBOOT0 = 1 (BOOT0 taken from BOOT0 pin)
- TZEN = 1 (TrustZone security enabled)
- NSBOOTADD0 = 0x100000 (User flash address 0x08000000)
- NSBOOTADD1 = 0x17F200 (System bootloader address 0x0BF90000)
- SECBOOTADD0 = 0x180080 (boot entry point address 0xc004000)
- SRAM2_RST = 0 (SRAM2 erased at each reset)
BR,
Younes
2023-03-23 3:04 AM
Hi @Domenico ,
I have flashed the SBSFU application with by mistake write protection enabled for flash address 0x08000000. I am unable to erase using jlink commander.exe as well as by IAR->project->Download->erase. Please suggest me how to erase the flash of STM32H743II.
2023-03-23 3:35 AM
@Domenico This is the error i am getting from the IAR IDE.
