STM32L0 - reset after setting RDP
JJRR
Senior
Dear,
I am setting RDP to level 1 in my application, After setting it I call System reset HAL_NVIC_SystemReset();
After reset I am expecting the MCU is locked, but it seems I read in code the MCU is still in level 0 so the procedure of setting RDP to level 1 is repeating. Only power disconnect locks the processor to level 1.
Any solution?
Best regards, Jan.
        HAL_FLASHEx_OBGetConfig(&flashTemp);
	if(OB_RDP_LEVEL_0 == flashTemp.RDPLevel)
		HAL_FLASH_OB_Unlock();
		HAL_FLASHEx_OBGetConfig(&pOBInit);
		pOBInit.RDPLevel = 0xBB;
		pOBInit.WRPState = OB_WRPSTATE_ENABLE;
		HAL_FLASHEx_OBProgram(&pOBInit);
		HAL_FLASH_OB_Lock();
5 REPLIES 5
What chip?
Look at the code:
https://github.com/STMicroelectronics/STM32CubeL0/blob/58c3ec5bb16e3475309da63f64d62efb2782594d/Drivers/STM32L0xx_HAL_Driver/Src/stm32l0xx_hal_flash_ex.c#L327
You need to add:
pOBInit.OptionType = OPTIONBYTE_RDP | OPTIONBYTE_WRP;
if you want to set those options.
STM32L071
Thanks, I didn't see it initially. I edited my post after asking. See the new answer.
Hi @Community member​ ,
Did you added the line suggested by @TDK​ ? Does it work this time?
If yes, please mark his reply as Best answer (click on "Select as Best").
-Amel
Funny how problems occur in pairs -- somewhat related.
You might probably need to reload the option bytes after programming, see Reloading Option bytes by software subchapter in RM.
