Why OCTOSPI registers aren't accessible on NUCLEO-L4R5ZI-P?
AGEBE.1
I'm trying to configure manually OCTOSPI registers in order to implement Hyperbus protocol but when I try to write registers it has no effect...
I'm using that command:
OCTOSPI1->CR = OCTOSPI1->CR | (0x1 << 0);
But the register keep it's value 0.
>>But where did you find this information?
I understand the problem space, an elephant with a tesseract if you will..
https://www.st.com/resource/en/reference_manual/dm00310109-stm32l4-series-advanced-armbased-32bit-mcus-stmicroelectronics.pdf
6 REPLIES 6
Imen.D
Hello @AGEBE.1​ ,
Have a look at this article, which will help you to configure OctoSPI, it's applicable for STM32L4 series.
Imen
Imen
Can you see any other registers, are they all zero?
Make sure all clocks are enabled
  1. //enable peripherals
  2. RCC->AHB3ENR |= RCC_AHB3ENR_OSPI1EN;
  3. RCC->AHB2ENR |= RCC_AHB2ENR_OSPIMEN;
On H7 there's also IOMNGREN (AHB3) OCTOSPI*M*
AGEBE.1
The other peripherial was all zero yes.
But thank you, you solved my problem!
AGEBE.1
0693W00000BbnorQAB.pngBut where did you find this information?
I can't find the bit associated to OSPI. According to stm32l4r5xx.h file, this bit is supposed to be the 8th of this register:
#define RCC_AHB3ENR_OSPI1EN_Pos             (8U)
Thanks a lot!
