when my mcu go to the standby mode then if i want to trigger extern interrupt after wakeup it is going to isr how its poosible to go isr and why i want when i give the external trigger during standby mode then it will start from the intial not a isr
Asing.3
3 REPLIES 3
KnarfB
Principal III
What chip? And, please show the relevant code.
Asing.3
thanks for reply soon this problem solved
now when i go standby mode as for documents it will take 5 micro ampere but it is taking 8.2 microcampere why sir
i am using the stm32l152RETX microcontroller
Mohamed Aymen HZAMI
Hello @Asing.3​ ,
You must put all unused GPIOs in analog mode to achieve adequate power consumption.
Best Regards,
Mohamed Aymen.
