2023-06-08 11:53 AM
2023-06-08 01:13 PM
Capture the signal in the same timing unit and calculate the phase shift?
2023-06-08 01:13 PM
2023-06-08 01:17 PM
Yes.
Phase shift between output of COPM2 (ZCD) and HRTIM master.
(COPM2 used as HRTIM External Event 1 source)
2024-05-13 07:14 AM
Did you found a solution? I'm now facing the same problem.
