Warning: The core is locked up
‎2025-01-01 4:19 AM
I am getting a warning "The core is locked up" and a few more (please refer to the attached image).
I have also tried flashing with the hex file, but some flashing issue is observed.
STM32H7 Series
‎2025-01-01 6:34 AM
NUCLEO-H753ZI
ST-LINK/V3
Is the device secure, and potentially blocking/disabling SWD/JTAG connectivity?
If you jumper BT0 and VDD does it behave differently?
High Quality USB 2.0 Cable? Not charging cable
Via Hub or Docking Station?
Had it worked reliably before/earlier?
Behaves this way on other computers?
‎2025-01-01 6:34 AM
NUCLEO-H753ZI
ST-LINK/V3
‎2025-01-01 11:01 PM
Hi Tesla DeLorean
I am using the Nucleo-H753ZI with ST-LINK/V3
- It is not blocking, I am able to connect it to target.
- Yes, I changed the Boot pin 0 to VDD (Core under reset is observed).
- Yes, ST's provided cable
- No
- Yes
- Yes
Devank J
