USB device with MTP
Hi
I can't find USB device with MTP example.
Is there any resource about USB device with MTP?
FBL
Hi @Zhou JianQiang
There is no current example of an MTP device using the ST library.
I'm out of offce with limited access to my emails.
Happy New Year!
5 REPLIES 5
FBL
Hello @Zhou JianQiang
USBX device class(Printer,MTP,CCID ) were brought by Azure RTOS starting from v6.1.10.
Here is an example of USB MTP device
x-cube-azrtos-h7/Projects/STM32H735G-DK/Applications/USBX/Ux_Device_PIMA_MTP at f48d941bcbe270bcb0b01c0fcedd3924db778d42 · STMicroelectronics/x-cube-azrtos-h7 (github.com)
Happy New Year!
Hi @FBL :
I want to use the library provided by ST(Middlewares\ST\STM32_USB_Device_Library\Class\MTP),  so there's no examples and document now, right?
What I should do is look at the examples, right?
FBL
Hi @Zhou JianQiang
You can find an example using F4 product under STM32Cube\Repository\STM32Cube_FW_F4_V1.28.0\Projects\STM324x9I_EVAL\Applications\USB_Host\MTP_Standalone then you can update the source code to match the hardware and peripheral configuration of your target.
Happy New Year!
Hi @FBL :
Thank you, I know the host MTP example, but I want to find a device MTP example.
I need to know how to combine MTP and SDMMC.
FBL
Hi @Zhou JianQiang
Happy New Year!
