USART line low
‎2022-05-25 6:27 AM
I'm working with an STM32G05, on a very simple custom board. I expose both USARTs to external headers.
USART1 seems to be operating fine - in that I can send/receive data.
However, USART2 is not.
When I inspected the TX line I discovered it was low, even at boot.
I check for anything that might be pulling it to ground, and there isn't anything on the board itself.
Is there something with the processor that could be causing this?
- Labels:
STM32G0 Series
UART-USART
‎2022-05-25 11:47 AM
I believe I have found a bug in cubeMX code generation.
Code generated for USART1 looks like this:
GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
The code generated for USART2 looks like this:
GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
GPIO_InitStruct.Alternate = GPIO_AF1_USART2;
I added
GPIO_InitStruct.Alternate = GPIO_AF1_USART1;
to the initialization structure for USART1 and now it works as expected.
‎2022-05-25 7:04 AM
What board are you using?
If it's a custom design, has it ever worked before?
If you change the TX line to be just a plain GPIO, can you set it high & low?
‎2022-05-25 11:20 AM
Thanks for that idea. The custom board has never been used - it's brand new.
I made PA9, and PA10 both GPIO Outputs and they are both toggling correctly.
I set them back to USART1, and USART1_TX (PA9) stays low.
I added
‎2022-05-25 3:12 PM
It does look wrong, but you originally stated that the issue was with USART2, not USART1
What did that failing code look like?
‎2022-05-25 3:40 PM
You're right. I made a mistake because for some reason I thought it was the secondary UART. After posting a bug I received this response:
https://community.st.com/s/question/0D53W000019Ctw4SAC/uart-not-configured-properly-for-stm32g061
It was confirmed by ST that it is a code generation issue,
‎2022-05-26 1:16 AM
If the issue is now resolved, please mark the solution:
