The sequence from the ADC_SQR3 register does not work.
‎2023-07-23 5:21 AM
static void MX_ADC1_Init(void)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ENABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 3;
hadc1.Init.DMAContinuousRequests = ENABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
void ADC_Select_CH0 (void)
ADC_ChannelConfTypeDef sConfig = {0};
sConfig.Channel = ADC_CHANNEL_5;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_480CYCLES;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
void ADC_Select_CH1 (void)
sConfig.Channel = ADC_CHANNEL_6;
sConfig.Rank = 2;
Error_Handler();
uint16_t a[10]={0};
while (1)
ADC_Select_CH5();
ADC_Select_CH6();
HAL_ADC_Start(&hadc1);
HAL_ADC_PollForConversion(&hadc1, 1000);
a[0] = HAL_ADC_GetValue(&hadc1);
HAL_ADC_Stop(&hadc1);
ADC
STM32F4 Series
‎2023-07-24 9:40 PM
#include "main.h"
#include <stdio.h>
uint16_t a[5]={0};
while (1)
a[0]=HAL_ADC_GetValue(&hadc1);
a[1]=HAL_ADC_GetValue(&hadc1);
printf("%d\n", a[0]);
printf("%d\n", a[1]);
hadc1.Init.NbrOfConversion = 2;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_7;
sConfig.Rank = 1;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_8;
sConfig.Rank = 2;
Error_Handler();
‎2023-07-23 7:27 AM
maybe because you set end of conversion -> single conversion
try
‎2023-07-23 2:22 PM - edited ‎2023-07-23 2:25 PM
No, that's not the reason. I changed this setting. The problem is that only the first Rank from the ADC_SQR3 register is measured. Second Rank is never measured for some reason.
My task is also to measure the second Rank from the ADC_SQR3 register.
‎2023-07-24 12:17 AM
Which STM32?
> My goal now is to understand how ADC works.
Then don't use Cube/HAL. It hides the details. Read the ADC chapter in manual, and write your own code.
How do you know?
Where do you set the sequence length?
‎2023-07-24 2:02 AM
‎2023-07-24 2:26 AM
Which STM32?
How do you know?
Well, I don't see it in ADC_SQR1.L, in the list of registers you've given.
As I've said, if you want to learn how ADC works, don't use Cube/HAL, write your own code based on reading and understanding the manual.
‎2023-07-24 3:11 AM
Thank you.
The SQR1 register actually contained the number 1.
I put 2, but it still didn't help.
ADC1->SQR1=2097152;
2097152==0010 0000 0000 0000 0000 0000
I have STM32F407VGT6
‎2023-07-24 3:30 AM
In my H723 ADC setup I'm using the HAL defines for setting the rank, because there's some bit shifting involved, but I don't know if that applies to the F4 as well.
sConfig.Rank = ADC_REGULAR_RANK_2;
‎2023-07-24 3:40 AM
This definitely works in STM32F407.
sConfig.Rank = 2;
Here is an example if I set ONLY the second Rank.
‎2023-07-24 3:53 AM - edited ‎2023-07-24 3:57 AM
The problem is that the DR register is 16 bit and when I write like this
then I load the result from only one Rank.
How to download the result from the second Rank
And when I write this
then the conversion always starts from the first Rank
Maybe the second Rank is being converted, but I just don't know how to save the result of the conversion.
