2022-07-24 7:57 AM
I bought Nucleo-L4R5ZI.
I can't find any document with HW information such as memory map, registers, etc. for Nucleo-L4R5ZI.
I could find a document with HW layout and other information.
Where can I find a document that contains HW information such as memory maps, registers, etc. for Nucleo-L4R5ZI?
2022-07-26 7:14 AM
@Myasu.1 "is my understanding correct that the above manual for Nucleo-L4R5ZI ?"
Just to be clear on the distinction between the board and the chip:
As the title says, That document is the Reference Manual (the Datasheet is a separate document) for the STM32L4+ Series MCUs
It applies to the MCUs themselves; it makes no difference what board the chips are mounted on - that is entirely outside the scope of that document.
However, the MCU mounted on a Nucleo-L4R5ZI board is an STM32L4+ Series MCUs - so this is, indeed, the relevant manual.
When your question is resolved, please mark the solution:
2022-07-24 8:12 AM
The schematic is under the "CAD Resources" tab of the NUCLEO-L4R5ZI page
Documentation for the STM32L4R5ZI is under that products page, pining in Data Sheet, registers in Reference Manual under "Documentation" tab
2022-07-25 2:34 AM
@Myasu.1 "I can't find any document with HW information such as memory map, registers, etc. for Nucleo-L4R5ZI"
Those things are defined by the microcontroller chip - not by the board it's on.
Therefore, as @Community member said, you need to be looking in the chip datasheet for that info.
"Where can I find a document"
The place to start for all documentation is always the Product Page - there is one for the board:
And one for the chip:
You can easily find the Product Page for a product by just putting its part number - here, eg, "STM32L4R5ZI" and "Nucleo-L4R5ZI" - into google.
(other internet search engines are available)
2022-07-26 6:56 AM
@Andrew Neil
@Community member
thank you for quick reply,
I understand that register, memory map information is not described in board manual.
I find the datasheet describing these information.
STM32L4+ Series advanced Arm®-based 32-bit MCUs - Reference manual
2022-07-26 7:14 AM
2022-07-27 5:21 AM
i understand that chip manual and board manual are differ.
