Systick overspeed?
‎2018-02-04 3:32 PM
I'm using an STM32F429ZI Nucleo-144 board with CubeMX, enabled FreeRTOS, LWIP, USARTs, IWDG, RTC. The HSE clock source is the on-panel ST-Link 8MHz, the LSE clock source is the on-board 32.768 kHz crystal oscillator.
Since I have recently upgraded to latest cube package version (upgraded FreeRTOS, HAL, CMSIS, Cube libs) I realized that the time base of the panel just got speedy. If I use it to calculate time (and not the RTC), I experience about a 20% overspeed.
I tried using bothe the Systick and Timer1 to provide the timebase source, with the same outcome.
Additional information is that I power the board from external 12V.
Any ideas why this symptoms may come up?
Here are the clock configs from Cube:
- Labels:
STM32F4 Series
SysTick
‎2018-02-05 8:09 AM
As Clive said, use MCO to push the clock out for monitoring
+1
Also, read out and post the content of relevant RCC and SYSTICK (STK) registers.
‎2018-02-05 1:31 PM
He is building a time machine
‎2018-02-05 2:57 PM
It seems that you have provided a lot of information, just not what others have asked for. 'Pretty sure' isn't going to be helpful in getting your code debugged.
Given that you have incorrect timing over two different and independent mechanisms, logic would dictate that you want to take a fresh look at your diagnosis.
‎2018-02-07 4:42 AM
I have configured the MCO with prescaler to output 2 MHz clocked from the system clock, also measured with a scope and found it to be precisely at the 2 MHz.
Also captured RCC register contents (see screenshot).
An additional finding: when the board starts up it measures time correctly up until about 1-2 hours. Then something goes wrong and the timing gets speedy. I have not yet been able to measrure MCO when the problem occurs, once I've done that I will publish my findings. Also I will start logging out the contents of registers to identify if something is changing after this 1-2 hours period.
Also one more info - the core clock is set to 180 MHz (power scale 1, overdrive enabled). Not sure if this is important or not.
‎2018-02-07 4:55 AM
And the Systick registers content?
Of course, both are interesting only when the problem occurs.
PS What debugger is this?
‎2018-02-07 5:02 AM
Also, can't there be some mistake/error in the process how do you observe the 'speedup'?
You wrote:
Systick is configured to run at 1kHZ rate. Based on this systick I do a single uptime calculation (basically storing elapsed seconds) to measure how long the board has been running since its latest (re)start.
Arithmetic overflows come into mind.
Can you please simply increment a 32-bit variable in the systick interrupt, and observe that one directly?
‎2018-02-07 6:07 AM
Using Eclipse with SystemWorkbench, GCC toolset.
Yes, I was also thinking about a possible overflow. However this is not just the systick, as I mentioned the same happens with the RTC running on an independent clock. However I will still do what you suggested.
I'm pretty sure finally this will be a banal issue.
- « Previous
- 1
- 2
- Next »
