2021-03-01 06:40 AM
Good afternoon,
Maybe is an obvious question.
I'm studying the default startup_stm32g030xx.s, a part of the syntax is figured out in the program manual of MCU and another part in the GNU AS command page.
But, for example, those following commands:
.syntax unified
.cpu cortex-m0
.fpu softvfp
.thumb
I can understand the meaning but I would like to know in which ST's document are described, which are the options, etc.
Thank you in advance,
Riccardo C.
2021-03-01 06:48 AM
2021-03-01 06:48 AM
2021-03-01 11:43 PM
Perfect
Thank you a lot @Community member and I'm sorry for the trivial question.
Riccardo C.
