The program is stuck in the highlighted code. What can I do to fix this issue. Im just trying to use a previous code to make the led blink/ stop blinking once the button is pressed.
MPena.1
KnarfB
Principal III
The code is waiting for the high speed external clock (HSE) to get ready. Do you have an external oscillator/quartz connected and is is working? For testing, you might switch to the HSI internal oscillator.
