STM32L496 Missing Bits in SVD-File
‎2024-04-25 4:51 AM
I just downloaded "STM32L496.svd" (Version 1.3) from ST homepage and noticed that there are missing bits in register definitions:
CCMR1:
Bit 16 - OC1M[3]
Bit 24 - OC2M[3]
CCMR2:
Bit 16 - OC3M[3]
Bit 24 - OC4M[3]
STM32L4 series
‎2024-05-28 2:38 AM
Hello @Stephan W.
The issue has been solved on the attached SVD file. It will be updated on the ST website ASAP.
Best Regards.
STTwo-32
‎2024-04-25 5:26 AM - last edited on ‎2024-05-20 3:43 AM by Amel NASRI
Hello @Stephan W.
Have you tested the same behavior on the Version 1.4 of this SVD file?
Best Regards.
STTwo-32
‎2024-04-25 6:21 AM
The version of file "stm32l496.svd" is 1.3 though the package version is 1.4.
This is the file I used for my test.
Stephan
‎2024-04-25 7:33 AM
Can you share the exact file and the concerned timers.
Best Regards.
STTwo-32
‎2024-04-25 7:53 AM
File "STM32L496.svd" in following archive:
https://www.st.com/resource/en/svd/stm32l4_svd.zip
Concerned are Timer TIM1 and TIM8 with the following missing bits:
Register CMR1:
Bit 16 - OC1M[3]
Bit 24 - OC2M[3]
Register CCMR2:
Bit 16 - OC3M[3]
Bit 24 - OC4M[3]
Stephan
‎2024-05-16 3:30 AM
Hello @Stephan W.
Sorry for my late feedback. The issue is confirmed and escalated internally for the concerned team under internal ticket number 181548. It will be updated on the coming versions.
Best Regards.
STTwo-32
‎2024-05-28 2:38 AM
Hello @Stephan W.
Best Regards.
STTwo-32
