2024-05-28 3:10 AM
Does ST mirco provide a readmade Touchscreen HMI solution which can be interfaced with an existing system and display inputs received through the exisiting system on the display with minimum modifications, should be easily configurable and adapt to variety of inputs for e.g. such as modbus. If not then please suggest some options which are avaialble in the market
Anuj
