STM32L412: can't toggle PD2 on a custom board
‎2024-06-13 2:52 AM - last edited on ‎2024-06-13 3:12 AM by mƎALLEm
Am working on STM32L412RBT6.
We made a custom PCB for our product and Am trying to PD2 as digital output as toggle function.
I can't able to find any high output at PD2. The pin PD2 is always remains low.
Please help me on this
GPIO-EXTI
STM32L4 Series
‎2024-06-13 8:09 AM - edited ‎2024-06-13 8:09 AM
@VasuManiV wrote:
Yes @mÆŽALLEm we have a nucleo board to evaluate our code. Even i have tested with that. Am getting low at that pin always. Even i have tried to make that pin high instead of toggling.
So here you confirm that even with NUCLEO-L412 board you're facing the same behavior? So I can test it from my side!
‎2024-06-13 8:11 AM
@mÆŽALLEm Yes please do test and let me know
‎2024-06-13 8:34 AM - edited ‎2024-06-13 8:36 AM
Sorry, but NUCLEO-L412 has an LQFP32 package which doesn't have GPIOD port on it especially pin PD2, could you please clarify?
https://www.st.com/en/evaluation-tools/nucleo-l412kb.html
‎2024-06-13 8:37 AM
No its a LQFP64 package. Please check the snap which i took from the NUCLEO-412RB schematic
‎2024-06-13 8:42 AM - edited ‎2024-06-13 8:42 AM
Umm well unfortunately I don't have this board (NUCLEO-64) on hands but I can provide you a very simple project on which I toggle PD2 and you can test from your side and get back with the result.
But you didn't answer that question: do you confirm that even with NUCLEO-L412 board you're facing the same behavior?
‎2024-06-13 8:47 AM
But pin 54 is PB3 , not PD2 . Right ?
Which LED is there ?
‎2024-06-13 9:02 AM
Attached a simple project toggling PD2.
But also need to check the solder bridges SB16 and SB18:
SB16: needs to be soldered and SB18 needs to be disconnected.
‎2024-06-13 9:03 AM
There is not LED in NUCLEO board. We need a LED to blink to show fault status in our application.
‎2024-06-13 9:08 AM
Sorry i forgot. Yes we are facing the same behavior in NUCLEO-L412RB board. As you can see that in schematic, PD2 is not going anywhere and it is coming directly to the connector. I have probed at the connector as well as in controller pin (54th).
‎2024-06-13 9:09 AM - edited ‎2024-06-13 9:09 AM
According to the datasheet pin 54 is PD2:
But in CubeMx if you create a project based on the NUCLEO-L412 board you get pin 54 is PB3! It's based on the default solder bridge SB18 soldered/SB16 disconnected:
