STM32L0x2 timer frequency off by 10%
‎2023-10-11 3:43 AM
Hello!
I'm trying to setup up timer6, i need to use it at different frequencies at different times. To test the timer i toggle an output pin in the ISR and measure the frequency with an oscilloscope, but the frequency is consistently off by about 10%.
Any suggestions to why this is? My solution would be to multiply the wanted frequency by some calibration factor.
I would like a frequency of 2 Hz, so the timer interrupts should be at 4 Hz to toggle on and off.
The timer setup is:
32 MHz PLLCLK
Prescaler = 125
Period = 64000
TIM
‎2023-10-11 3:56 AM - edited ‎2023-10-11 3:59 AM
Use N-1 values to divide by N
124 to divide by 125
63999 for divide by 64000
‎2023-10-11 4:05 AM
Of course, thanks!
Now it's is off by 0.5 % but i guess that's because of the error tolerance of the clock=?
‎2023-10-11 6:56 AM
0.5% is within the tolerance of the internal HSI, if that's what you're using as a clock. A crystal will provide a much more accurate clock, to tens of ppm or so. The HSI can also be trimmed, but is not going to be stable long term or across temperatures.
