STM32L071 Multiple channels ADC using DMA
LPetr.1
Senior
Hey. I am trying to read multiple ADC channels using DMA but with no luck. My project settings:
I have selected 4 channels and enabled Continuous conversion mode as well as DMA Continuous requests.
I have also created a circular DMA for ADC :
#include "main.h"
#include  <errno.h>
#include  <sys/unistd.h> // STDOUT_FILENO, STDERR_FILENO
 ADC_HandleTypeDef hadc;
DMA_HandleTypeDef hdma_adc;
UART_HandleTypeDef huart1;
static void MX_ADC_Init(void);
static void MX_DMA_Init(void);
static void MX_USART1_UART_Init(void);
int _write(int file, char *data, int len)
   if ((file != STDOUT_FILENO) && (file != STDERR_FILENO))
      errno = EBADF;
      return -1;
   // arbitrary timeout 1000
   HAL_StatusTypeDef status =
      HAL_UART_Transmit(&huart1, (uint8_t*)data, len, 1000);
   // return # of bytes written - as best we can tell
   return (status == HAL_OK ? len : 0);
uint16_t dma_buf[4];
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_ADC_Init();
  MX_DMA_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
  HAL_ADC_Start_DMA(&hadc, dma_buf, 4);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
	  HAL_Delay(1000);
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
    Error_Handler();
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    Error_Handler();
  * @brief ADC Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN ADC_Init 0 */
  /* USER CODE END ADC_Init 0 */
  ADC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN ADC_Init 1 */
  /* USER CODE END ADC_Init 1 */
  /** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
  hadc.Instance = ADC1;
  hadc.Init.OversamplingMode = DISABLE;
  hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc.Init.Resolution = ADC_RESOLUTION_12B;
  hadc.Init.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
  hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc.Init.ContinuousConvMode = ENABLE;
  hadc.Init.DiscontinuousConvMode = DISABLE;
  hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc.Init.DMAContinuousRequests = ENABLE;
  hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  hadc.Init.LowPowerAutoWait = DISABLE;
  hadc.Init.LowPowerFrequencyMode = DISABLE;
  hadc.Init.LowPowerAutoPowerOff = DISABLE;
  if (HAL_ADC_Init(&hadc) != HAL_OK)
    Error_Handler();
  /** Configure for the selected ADC regular channel to be converted.
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
  if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_1;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_2;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_3;
    Error_Handler();
  /* USER CODE BEGIN ADC_Init 2 */
  /* USER CODE END ADC_Init 2 */
  * @brief USART1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART1_Init 0 */
  /* USER CODE END USART1_Init 0 */
  /* USER CODE BEGIN USART1_Init 1 */
  /* USER CODE END USART1_Init 1 */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART1_Init 2 */
  /* USER CODE END USART1_Init 2 */
  * Enable DMA controller clock
  /* DMA controller clock enable */
  __HAL_RCC_DMA1_CLK_ENABLE();
  /* DMA interrupt init */
  /* DMA1_Channel1_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
  * @param None
  * @retval None
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOA_CLK_ENABLE();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  __disable_irq();
  while (1)
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
As you can see I have created an array of size 4 for my DMA buffer:
and I start the DMA:
I set a breakpoint in while loop every 1 second and have added dma_buf to the expressions. Only the first element of an array is getting filled and it seems that it is a wrong value. I have about 2.9V on that pin so a reading should be about 3600 or 3500:
4 REPLIES 4
LPetr.1
Senior
I have also attempted to try and read multiple channels using polling method instead of DMA.
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
	  HAL_ADC_Start(&hadc);
	  HAL_ADC_PollForConversion(&hadc, HAL_MAX_DELAY);
	  uint16_t adc_value1 = HAL_ADC_GetValue(&hadc);
	  //HAL_ADC_Start(&hadc);
	  uint16_t adc_value2 = HAL_ADC_GetValue(&hadc);
	  uint16_t adc_value3 = HAL_ADC_GetValue(&hadc);
	  uint16_t adc_value4 = HAL_ADC_GetValue(&hadc);
	  uint16_t adc_value5 = HAL_ADC_GetValue(&hadc);
	  uint16_t adc_value6 = HAL_ADC_GetValue(&hadc);
	  uint16_t adc_value7 = HAL_ADC_GetValue(&hadc);
	  uint16_t adc_value8 = HAL_ADC_GetValue(&hadc);
	  uint16_t adc_value9 = HAL_ADC_GetValue(&hadc);
	  uint16_t adc_value10 = HAL_ADC_GetValue(&hadc);
	  printf("adc_value 1 = %u \n",adc_value1);
	  printf("adc_value 2 = %u \n",adc_value2);
	  printf("adc_value 3 = %u \n",adc_value3);
	  printf("adc_value 4 = %u \n",adc_value4);
	  printf("adc_value 5 = %u \n",adc_value5);
	  printf("adc_value 6 = %u \n",adc_value6);
	  printf("adc_value 7 = %u \n",adc_value7);
	  printf("adc_value 8 = %u \n",adc_value8);
	  printf("adc_value 9 = %u \n",adc_value9);
	  printf("adc_value 10 = %u \n",adc_value10);
	  printf("\n");
	  HAL_ADC_Stop(&hadc);
	  HAL_Delay(1000);
I am getting the strangest results, when ADC0 is shorted to ground(adc_value 5 changed)
adc_value 1 = 3554
adc_value 2 = 3486
adc_value 3 = 3602
adc_value 4 = 3605
adc_value 5 = 66
adc_value 6 = 3520
adc_value 7 = 3560
adc_value 8 = 3486
adc_value 9 = 3521
adc_value 10 = 3606
when ADC1 is shorted to ground, none of the values change
adc_value 1 = 3546
adc_value 2 = 3462
adc_value 3 = 3394
adc_value 4 = 3462
adc_value 5 = 3594
adc_value 6 = 3523
adc_value 7 = 3560
adc_value 8 = 3462
adc_value 9 = 3504
adc_value 10 = 66
when ADC2 is shorted to ground (adc value4 and ac value10 are changed):
adc_value 1 = 3550
adc_value 2 = 3469
adc_value 3 = 3397
adc_value 4 = 66
adc_value 5 = 3600
adc_value 6 = 3524
adc_value 7 = 3561
adc_value 8 = 3469
adc_value 9 = 3510
adc_value 10 = 66
When ADC3 is shorted to ground adc value 3 change
adc_value 1 = 3543
adc_value 2 = 3462
adc_value 3 = 66
adc_value 4 = 3610
adc_value 5 = 3604
adc_value 6 = 3528
adc_value 7 = 3564
adc_value 8 = 3461
adc_value 9 = 3291
adc_value 10 = 3612
when ADC4 is shorted to ground, adc_value 9 change:
adc_value 1 = 3533
adc_value 2 = 3200
adc_value 3 = 3602
adc_value 4 = 3609
adc_value 5 = 3605
adc_value 6 = 3524
adc_value 7 = 3557
adc_value 8 = 3200
adc_value 9 = 66
adc_value 10 = 3610
when ADC5 is shorted to ground adc value 2 and and value 8 change:
adc_value 1 = 3316
adc_value 2 = 68
adc_value 3 = 3608
adc_value 4 = 3616
adc_value 5 = 3611
adc_value 6 = 3523
adc_value 7 = 3554
adc_value 8 = 66
adc_value 9 = 3534
adc_value 10 = 3616
when ADC6 is shorted to ground, adc_value 1 is changed:
adc_value 1 = 66
adc_value 2 = 3484
adc_value 3 = 3607
adc_value 4 = 3610
adc_value 5 = 3606
adc_value 6 = 3508
adc_value 7 = 3308
adc_value 8 = 3484
adc_value 9 = 3530
adc_value 10 = 3612
and etc.... As you can see, it is messed up. Could someone help me understand why would that happen?
well spotted. That was indeed an issue with the CubeMX generating code in wrong order. What a silly mistake form CubeMX side. Thanks
Piranha
Chief II
With 1,5 sampling cycles the total conversion time is 14 cycles. Those are ADC clock cycles, but it's still pretty fast. The code of the HAL broken bloatware just cannot keep up to such speeds, especially when compiled in debug mode with no optimizations. And, even with a decent optimal code, which disables interrupts, capturing multiple ADC channels without DMA is not a good design.
