STM32L0 VREFBUF register config
‎2022-09-16 12:40 AM
I am using the STM32L071 with the latest STM32 studio software. I cannot find any sign of the VREFBUF configuration in the libraries (I need to enable the internal voltage reference for the COMP1 peripheral). I have found this article for H7 device:
https://st.force.com/community/s/article/how-to-configure-vrefbuf-on-my-stm32
But it seems that the VREFBUF entry in the graphical interface is missing (in the libraries code as well).
I would appreciate all help and feedback.
- Labels:
COMP
STM32L0 Series
‎2022-09-16 3:45 AM
Hi @Community member​
If you refer to RM0377, you can conclude that the Voltage reference buffer "VREFBUF" is not supported in STM32L0x1 devices.
Kaouthar
‎2022-09-16 3:45 AM
Kaouthar
‎2022-09-16 3:47 AM
Thank you for the answer @KDJEM.1​ ,
Currently I am unable to force the COMP1 interrupt, so I assumed the internal VREF is not turned on- could you help me turning it on in case that is the issue? I have set it as the COMP "-" input source.
‎2022-09-16 8:24 AM
Hello @Community member​ ,
If you use the STM32CubeMX, make sure that select the interrupt mode with Rising/Falling edges detection in Trigger mode as shown in the below figure.
Also, I advise you to get inspired from the available COMP_Interrupt example in the STM32CubeL0 MCU package.
This example may help you in the configuration by following the instructions in the readme file.
Kaouthar
‎2022-09-16 9:15 AM
Thanks @KDJEM.1​ , what I was missing is:
/*##-2- Configure the Vref #################################################*/
/* Enable the Vrefint */
HAL_COMPEx_EnableVREFINT();
/*##-3- Start teh COMP1 and enable the interrupt ###########################*/
if(HAL_COMP_Start(&hcomp1) != HAL_OK)
/* Initiliazation Error */
Error_Handler();
Now it works.
