2024-08-19 12:54 AM
tying to find what frequency the hsi is at startup and normally i search the datasheet for clocks and startup but this returns nothing in the datasheet for the stm32h753bi mcu only thing i see is that it has 4 clocks and it says the hsi is 64mhz is this it
2024-08-19 01:03 AM - edited 2024-08-19 01:04 AM
You're right , it's 64Mhz.
2024-08-19 01:03 AM
Hello @Franksterb92
the HSI Clock frequency is indicated, as you said, on the DS12117:
Best Regards.
STTwo-32
