Stm32H743 ADC 16bit Really ?
‎2024-04-11 7:13 AM
The cubemx example for ADC scan of internal channels for 743-eval shows the converted values being multiplied by 4. So is it really 16 bit or 14? I have verified the necessity of multiplying by 4 to get correct readings for VBat.
STM32H7 series
‎2024-04-12 10:26 AM
Hello @GreenGuy
There is an internal resistor divider by 4 between VBAT pin and ADC3_INP17 input channel.
Check the DS12110 Rev 10 in Table 192. VBAT monitoring characteristics the Q ratio on internal VBAT measurement.
It's also explained in RM0433 in section Table 192. VBAT monitoring characteristics.
This is why the ADC_InternalChannelConversion example compute the VBAT voltage and multiply the ADC3_INP17 by Q=4. ADC3 on STM32H74x/75x are 16bits resolution.
Hope it answers to your question.
Best regards,
Romain,
‎2024-04-11 8:05 AM
And how is resolution (i.e. ADC_CFGR.RES) set?
‎2024-04-11 8:08 AM
AN5354 "Getting started with the STM32H7 Series MCU 16-bit ADC"
‎2024-04-11 3:18 PM
I have read an5354 previous to posting. It says nothing regarding choices made in the example for the stm32h743-eval example.
‎2024-04-11 3:19 PM
In cubemx it is set to 16bit. But your question is a good one and I will have to view the register in the debugger to see what is actually being set.
Hello @GreenGuy
Best regards,
Romain,
