2024-03-19 02:57 AM - last edited on 2024-03-19 03:33 AM by Peter BENSCH
BOOT0 Input equivalent circuit data cannot be found. Please let me know if you have any materials.
2024-03-19 05:47 AM
Since BOOT0 takes 0-9V and since no current injection is allowed, we can conclude that BOOT0 likely does not have a parasitic protection diode.
2024-03-19 03:15 AM
Hello @mon and welcome to the ST Community
Can you give more details about your request.
Best Reagrds.
STTwo-32
2024-03-19 03:43 AM
回路の接続を確認したいのです。
GPIOの等価回路図では、入力に寄生ダイオードがあります。
BOOT0ポートに寄生ダイオード構成があるか確認したいのです。
2024-03-19 04:12 AM
Hello @mon ,
Please develop your questions/comments in English to let other members help you efficiently.
Thank you for your understanding.
Translation:
"I want to check the circuit connections.
In the equivalent circuit diagram of GPIO, there is a parasitic diode at the input.
I want to check if there is a parasitic diode configuration on the BOOT0 port."
2024-03-19 05:47 AM
