STM32G474 Flash wait states at 170MHz CPU clock
Oblomkov.Ilya
RM0440 Rev 3 (last version) recomend to set 4WS for 170MHz CPU clock
RM0440 Rev 2 recomend to set 8WS for 170MHz CPU clock
ST driver library (STM32G4xx_HAL_Driver) function LL_PLL_ConfigSystemClock_HSE() set 8WS for 170Mhz clock.
Which Flash WS setting is right for 170MHz, 4WS or 8WS?
hamdi.najoua
The new specification is applicable to all STM32G4 family products.
In fact, the Flash is re-characterized and it is found that the maximum number of wait-states can be reduced from 8 to 4 wait states and so it is possible to achieve 170MHz at only 4 wait-states  which has an interesting impact on the performance.
This new specification will be taken into account in the STM32CubeG4 next version planned for W26.
Best regards,
Najoua.
15 REPLIES 15
berendi
Principal
I assume that the reference manual was updated for a reason.
The last update of RM0440 is more recent than the latest version of the library.
This is quite a dramatic change.
It would be nice to hear from ST, what's the reason for this change, and whether it's result of change described in PCN MDG/19/11871 - i.e. whether' it's applicable also for the older revision of the 'G4 chips or not.
@Amel NASRI​ , can we please have a comment on this?
Uwe Bonnes
Principal III
Where to get that PCN?
Some distributors make them available for the commoners, e.g. http://www.anglia.com/registration/pcn_ptn/docs/pcn/st_PCN%20MDG_19_11871.pdf
Uwe Bonnes
Principal III
Hopefully an updated errata sheet appears soon.
hamdi.najoua
Best regards,
Najoua.
I'd love to hear about data on the performance improvement between the old and new settings for a few relevant workloads - could be the standard workloads, power consumption change, Field oriented control motor control implementation, etc.
Hi Najoua,
Thanks for the comment.
So, does this mean, that the 4WS applies also to the older revisions of the 'G4 chips?
Thanks,
@hamdi.najoua​
