STM32G070 Startup file
DRobe.4
Senior
I created a Keil project for STM32G070 without using Cube. It compiles but the link fails with error L6236E which seems to indicate there is no startup file. Can anyone send me a file that will work? In case it matters, the board that I am using is a cheapie Aliexpress that basically has the CPU and a 8 MHz xtal oscillator.
gbm
Principal
In Manage Run-time environment window (opened via the greenest button), tick CMSIS - Core and Device - Startup
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
3 REPLIES 3
Should be in the driver cmsis device source template arm​ directory
gbm
Principal
DRobe.4
Senior
Thanks for your helop.
