STM32G030K6T6 ADC_DMA
‎2023-04-28 6:20 AM
I'm trying to configure the ADC DMA with STM32G030K6T6. But Analog value is not came.
below I given my code and i don't know where i made a mistake if any one know help me.
void ADC_Config(void)
RCC->APBENR2 |= RCC_APBENR2_ADCEN; // ADC clock enable
RCC->AHBENR |= RCC_AHBENR_DMA1EN; // DMA1 clock enable
ADC1->CR |= ADC_CR_ADEN; // ADC enable
ADC1->CFGR2 |= (1<<30); // 01: PCLK/2 (Synchronous clock mode)
ADC1->CFGR1 |= (ADC_CFGR1_CONT | ADC_CFGR1_DMAEN | ADC_CFGR1_CHSELRMOD | ADC_CFGR1_DMACFG); // 1: Continuous conversion mode & Direct memory access enable & Direct memory access configuration
ADC1->SMPR |= ADC_SMPR_SMP1_1; // Sampling time selection 1 (010: 7.5 ADC clock cycles)
ADC1->CHSELR |= (ADC_CHSELR_CHSEL0 | ADC_CHSELR_CHSEL1 | ADC_CHSELR_CHSEL2); // Channel-x selection (Channel-x selection)
DMA1_Channel1->CPAR = (uint32_t)&(ADC1->DR); // peripheral Address
DMA1_Channel1->CMAR = (uint32_t)Aout; // Memory Address
DMA1_Channel1->CNDTR = 3; // No Of Data
DMA1_Channel1->CCR |= (DMA_CCR_MINC | DMA_CCR_MSIZE_0 | DMA_CCR_PSIZE_0| DMA_CCR_CIRC | DMA_CCR_TEIE | DMA_CCR_TCIE); // Msize,Psize,CIRC,MINC
DMA1_Channel1->CCR |= DMA_CCR_EN; // DMA enable
NVIC_EnableIRQ(DMA1_Channel1_IRQn);
NVIC_SetPriority(DMA1_Channel1_IRQn,0);
ADC
DMA
STM32G0 Series
‎2023-05-08 12:27 AM
First try run my example because it's hardware agnostic. Independent against external devices. When my examples will be valid, then try run on other channels
‎2023-05-08 4:53 AM
I use the same code output is came in ADC->DR only.but output is not came in Aout variable.
‎2023-05-08 4:54 AM
Show me all code related to this variable Aout
‎2023-05-08 4:59 AM
How is DMAMUX set?
‎2023-05-08 5:03 AM
I use stm32cubeide for STM32G030K6T6 Microcontroller, HAL_ADC_Start_DMA(&hadc1, Aout, 3) is not working outside(user code begin 2) the while loop. In bulepill board, this comment is working outside(user code begin 2) & inside the while loop. In STM32G030K6T6 Microcontroller, why this comment is not working outside(user code begin 2) the while loop?
‎2023-05-08 5:34 AM
hi @Kamil Duljas​,
below i given my code,
#include<stm32g030xx.h>
volatile uint32_t Aout[3];
int main()
RCC->IOPENR |= (RCC_IOPENR_GPIOAEN); // I/O port A clock enable
GPIOA->MODER &= ~(GPIO_MODER_MODE0 | GPIO_MODER_MODE1 | GPIO_MODER_MODE2); // clear 0, 1, 2 pin
GPIOA->MODER |= (GPIO_MODER_MODE0_0 | GPIO_MODER_MODE0_1 | GPIO_MODER_MODE1_0 | GPIO_MODER_MODE1_1 | GPIO_MODER_MODE2_0 | GPIO_MODER_MODE2_1); // 11: Analog mode
DMA1_Channel1->CMAR =(uint32_t)&Aout; // Memory Address
DMA1_Channel1->CCR |= (DMA_CCR_MINC | DMA_CCR_MSIZE_1 | DMA_CCR_PSIZE_1| DMA_CCR_CIRC | DMA_CCR_TEIE); // Msize,Psize,CIRC,MINC
ADC1->CHSELR |= (ADC_CHSELR_CHSEL1); // Channel-x selection (Channel-x selection)
ADC1->ISR &= ~(ADC_ISR_EOC | ADC_ISR_EOS | ADC_ISR_OVR);
ADC1->CR |=ADC_CR_ADSTART;
while(1)
void DMA1_Channel1_IRQHandler(void)
while(!(DMA1->ISR & DMA_ISR_TCIF1)); // Check Transfer Complete Flag
DMA1->IFCR |= DMA_IFCR_CTCIF1; // Clear Transfer Complete Flag
‎2023-05-08 6:09 AM
hi @Community member​
How to configure DMAMUX for ADC ?
‎2023-05-08 6:35 AM - edited ‎2023-11-20 6:51 AM
I don't use the 'G0, but generally, you look at the input requests mapping table:
and write the number of request (here: 5) into the chosen DMAMUX channel's DMAMUX_CxCR.DMAREQ_ID register.
Note, that DMAMUX channels are onfusingly numbered starting with 0, whereas DMA channels are numbered starting with 1, so for DMA1 Channel1 you should use DMAMUX channel 0.
- « Previous
- 1
- 2
- Next »
