STM32G Series External EEPROM Problem
Merttg7
Hello Everyone​
When I try to save data to external eeprom using stm32g030 with hal libraries, I can't save any data but I can do the same with other stm32l or stm32f0, stm32f1, stm32f2, stm32f4 series processors. What is the problem ?
Has anyone had this problem and found a solution?
Thank you.
3 REPLIES 3
Andrew Neil
Evangelist III
What debugging have you done to find the problem?
Have you used an oscilloscope, logic analyser, or similar to see what's actually happening on the wires?
Merttg7
Hi Andrew,
ı tried everything but it didn't work with hal libraries.
I solved the problem using eeprom.c and eeprom.h
Thank you very much.
Have a nice day.
So what debugging have you done? What did you find?
Have you used an oscilloscope or analyser to see what's actually happening on the wires? What did you find?
