2024-04-29 7:22 PM - last edited on 2024-04-30 2:04 AM by mƎALLEm
Hi all,
I used the same setting and the same software, keil uVision5. The only different is use my own board rather than EVB, STM32F769I-EVAL. BTW, I use my own board and STM32 ST-Link utility.
Sometimes I can successfully go to debug mode, but sometimes I can't.
My question is why keil uVision5 shows 'Error: Flash Download failed - ''Cortex-M7'''.
I had erased first then rebuild finished, the next step is starting debug session. Unlucky, it shows error.
May need your support on this issue, thank you.
2024-04-30 2:11 AM
You need to check your hardware of your own board. Check the VCAPx pins voltage and compare them to what was stated in the datasheet:
Check also the power supply VDD.
Did you refer to the documentation like AN4661 when you started to design your board (see Figure 24 for reference design)?
2024-04-30 2:11 AM
