stm32F429BI + LCD does not switch-on the display
I am starting some test with this module
https://it.aliexpress.com/item/1005002482177244.html
with 7” lcd
I have found only one example that run but with Touchgfx
I have got the same ioc from this example to generate a new code and insert the functions to switch on lcd but still no result
I would like to use the normal functions
BSP_LCD_Init() ;
BSP_LCD_DisplayStringAt(10, 80, buf, LEFT_MODE);
BSP_LCD_DrawBitmap(0, 0, (uint8_t *)(&BackGround0));
45 REPLIES 45
I have found this set in the example of the Alixpress module but the output result is the same
#define HBP 80 // ¸ù¾ÝÆÁÄ»µÄÊÖ²á½øÐÐÉèÖÃ
#define VBP 40
#define HSW 1
#define VSW 1
#define HFP 190
#define VFP 22
#define LCD_Width 800
#define LCD_Height 480
#define LCD_Pixels 800*480
#define LCD_MemoryAdd 0xD0000000
hltdc.Instance = LTDC;
hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL;
hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL;
hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL;
hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
hltdc.Init.HorizontalSync = HSW - 1;
hltdc.Init.VerticalSync = VSW -1 ;
hltdc.Init.AccumulatedHBP = HBP + HSW -1;
hltdc.Init.AccumulatedVBP = VBP + VSW -1;
hltdc.Init.AccumulatedActiveW = LCD_Width + HSW + HBP -1;
hltdc.Init.AccumulatedActiveH = LCD_Height + VSW + VBP -1;
hltdc.Init.TotalWidth = LCD_Width + HSW + HBP + HFP - 1;
hltdc.Init.TotalHeigh = LCD_Height + VSW + VBP + VFP - 1;
Need to fix BSP_RGB_LCD.c
#define XSIZE_PHYS 1024 // WRONG
#define YSIZE_PHYS 600  // WRONG
#define HBP  2 // NOT SURE WHERE USED
#define VBP  2 // BACK PORCH
#define HSW  10
#define VSW  2 // SYNC
#define HFP  2
#define VFP  2 // FRONT PORCH
Ok so a FANKE RGB070M1 800x480 V1.4 with AT070TN92 panel
https://www.beyondinfinite.com/lcd/Library/Innolux/AT070TN92.pdf
Timing clocks in here
stm32F429BI-test2\Core\Src\stm32f4xx_hal_msp.c
You've got LTDC initialization in main.c via MX_LTDC_Init()
Back + Active + Front
Horizontal 64 + 800 + 210 = 1056
Vertical 23 + 480 + 22 = 525
Sync needs to come out of the back budget
Horizontal sync 1 - 40
Vertical sync 1 - 20
LTDC has a counter, hence the "accumulated" value so you can hit each count
www.audiodesignguide.com/sw1/stm32F429BI-test3.zip
near to the final result but why it is blue ?
the main code:
HAL_GPIO_WritePin(LCD_BACKLIGHT_GPIO_Port, LCD_BACKLIGHT_Pin, GPIO_PIN_SET);
BSP_LCD_Init();
//osDelay(1000);
#define WHITE 0xFFFF
#define BLACK 0x0000
//Paint_NewImage(800, 480, 0, WHITE);
BSP_LCD_Clear(WHITE);
here the set:
static void MX_LTDC_Init(void)
LTDC_LayerCfgTypeDef pLayerCfg = {0};
LTDC_LayerCfgTypeDef pLayerCfg1 = {0};
#define HBP 80
#define VBP 40
#define HSW 1
#define VSW 1
#define HFP 190
#define VFP 22
hltdc.Init.Backcolor.Blue = 0;
hltdc.Init.Backcolor.Green = 0;
hltdc.Init.Backcolor.Red = 0;
if (HAL_LTDC_Init(&hltdc) != HAL_OK)
Error_Handler();
pLayerCfg.WindowX0 = 0;
pLayerCfg.WindowX1 = 799;
pLayerCfg.WindowY0 = 0;
pLayerCfg.WindowY1 = 479;
pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_ARGB8888;
pLayerCfg.Alpha = 255;
pLayerCfg.Alpha0 = 0;
pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
pLayerCfg.FBStartAdress = 0xD0000000;
pLayerCfg.ImageWidth = 800;
pLayerCfg.ImageHeight = 480;
pLayerCfg.Backcolor.Blue = 0;
pLayerCfg.Backcolor.Green = 0;
pLayerCfg.Backcolor.Red = 0;
if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, 0) != HAL_OK)
Error_Handler();
pLayerCfg1.WindowX0 = 0;
pLayerCfg1.WindowX1 = 799;
pLayerCfg1.WindowY0 = 0;
pLayerCfg1.WindowY1 = 479;
pLayerCfg1.PixelFormat = LTDC_PIXEL_FORMAT_ARGB8888;
pLayerCfg1.Alpha = 0;
pLayerCfg1.Alpha0 = 0;
pLayerCfg1.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
pLayerCfg1.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
pLayerCfg1.FBStartAdress = 0;
pLayerCfg1.ImageWidth = 0;
pLayerCfg1.ImageHeight = 0;
pLayerCfg1.Backcolor.Blue = 0;
pLayerCfg1.Backcolor.Green = 0;
pLayerCfg1.Backcolor.Red = 0;
if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg1, 1) != HAL_OK)
Error_Handler();
My blind stab at this would be, might be some N-1 issues
// 33.3 MHz PIXEL CLOCK  AT070TN92 / FANKE RGB070M1 800x480 V1.4
#define HSIZE_ACTIVE 800
#define VSIZE_ACTIVE 480
#define HSYNC 20
#define HBP 64
#define HFP 210
#define VSYNC 9
#define VBP 23
#define VFP 22
  hltdc.Init.HorizontalSync = HSYNC;
  hltdc.Init.VerticalSync = VSYNC;
  hltdc.Init.AccumulatedHBP = HBP;
  hltdc.Init.AccumulatedVBP = VBP;
  hltdc.Init.AccumulatedActiveW = hltdc.Init.AccumulatedHBP + HSIZE_ACTIVE;
  hltdc.Init.AccumulatedActiveH = hltdc.Init.AccumulatedVBP + VSIZE_ACTIVE;
  hltdc.Init.TotalWidth = hltdc.Init.AccumulatedActiveW + HFP;
  hltdc.Init.TotalHeigh = hltdc.Init.AccumulatedActiveH + VFP;
Guessing the LTDC clock is 25 MHz, needs to be 33.3 MHz, or so
void HAL_LTDC_MspInit(LTDC_HandleTypeDef* hltdc)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  if(hltdc->Instance==LTDC)
  /* USER CODE BEGIN LTDC_MspInit 0 */
  /* USER CODE END LTDC_MspInit 0 */
  /** Initializes the peripherals clock 25/15 = 1.6667 MHz fComp
    PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LTDC;
    PeriphClkInitStruct.PLLSAI.PLLSAIN = 80; // 60=25MHz, 80=33.3MHz ??
    PeriphClkInitStruct.PLLSAI.PLLSAIR = 2;
    PeriphClkInitStruct.PLLSAIDivR = RCC_PLLSAIDIVR_2;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
      Error_Handler();
    /* Peripheral clock enable */
    __HAL_RCC_LTDC_CLK_ENABLE();
I will try tomorrow your set
ok, Tesla DeLorean
I will test tomorrow morning
Tesla DeLorean, Your set not RUN
This RUN and show a blue screen
PeriphClkInitStruct.PLLSAI.PLLSAIN = 60;
#define HBP 80
#define VBP 40
#define HSW 1
#define VSW 1
#define HFP 190
#define VFP 22
    run
HBP80 AccumulatedHBP40
VBP40 AccumulatedVBP40
HSW1 HorizontalSync0
VSW1 VerticalSync0
HFP190 AccumulatedActiveW880
VFP22 AccumulatedActiveH520
LCD_Width800 TotalWidth1071
LCD_Height480 TotalHeigh543
