STM32F412 CAN Transmits unexpected data
JDOG
When I trigger a transmit of a test CAN message on CAN bus 2 the CAN module transmits unexpected data when I look at CAN bus with a logic analyzer. PCAN does receive the unexpected message and it does acknowledge the massage.
 Here is what I see on the CAN Bus.
PCAN Receive:
1 REPLY 1
Karl Yamashita
Principal
Set your variables to global. Once your leave the SendCAN_Message function, the variables are destroyed.
Don't worry, I won't byte.
TimerCallback tutorial! | UART and DMA Idle tutorial!
