STM32F407VE USART DMA RECEIVE
HNguy.6
Hello everyone, I am a beginner on STM32F4. I want to using DMA for receiving data via USART. But it doesnot work, please help me to solve the problem. Here is my code:
void USART2_ConfigDMA(void)
  DMA_InitTypeDef DMA_InitStructure;
  RCC->AHB1ENR = RCC_AHB1ENR_DMA1EN;
  DMA_InitStructure.DMA_BufferSize = 10;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable ;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull ;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single ;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_PeripheralBaseAddr =(uint32_t) (&(USART2->DR)) ;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_Channel = DMA_Channel_4 ;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory ;
  DMA_InitStructure.DMA_Memory0BaseAddr =(uint32_t)&data[0];
  DMA_Init(DMA1_Stream5,&DMA_InitStructure);
  USART_Cmd(USART2, ENABLE);
  USART_DMACmd(USART2, USART_DMAReq_Rx, ENABLE);
  DMA_Cmd(DMA1_Stream5, ENABLE);
Thanks for your support !
Probably want to start by ORing clock enable bits, rather than blind writing..
RCC->AHB1ENR |= RCC_AHB1ENR_DMA1EN;
3 REPLIES 3
Thank you ! I have solved the problem.
I have one more problem. I cannot received data continuously using DMA, please help me !:
  while(1)
    if (USART_GetFlagStatus(USART2, USART_FLAG_IDLE)==RESET)
      /* clear buffer */
      clear_buffer(SEMEATECH_RECEIVE);
      // USART_Cmd(USART2, ENABLE);
    else if (USART_GetFlagStatus(USART2, USART_FLAG_IDLE)==SET)
      // USART_Cmd(USART2, DISABLE);
      USART_DMACmd(USART2, USART_DMAReq_Rx, DISABLE);
      DMA_Cmd(DMA1_Stream5, DISABLE);
      UART_DISPLAY_DATA(10);
    delay_ms(500);
