STM32F407 Continuous Conversion Issue Using ADC and DMA
‎2024-03-13 4:25 AM
I am currently using ADC for continuous conversion. Below is my program.
My ADC conversion is only successful after the first reset, and the Rxdata values are all zero.
Does any expert know where the problem is in my program?
- Labels:
ADC
DMA
STM32F4 Series
‎2024-03-13 6:49 AM
Rxdata should be defined as volatile.
‎2024-03-13 8:21 PM
Yes, you're right, here it should be changed to 0X1, but the result remains the same as before.
I've tried comparing it with mx, but still don't know where the problem is.
‎2024-03-14 6:49 AM
Keep trying. Show a screenshot with your values and the values from CubeMX. If one works and the other doesn't, there's a difference somewhere.
‎2024-03-15 6:55 AM - edited ‎2024-03-15 6:55 AM
Always start debugging peripherals by reading out and checking content of relevant registers - here, ADC and DMA.
If you'd do that, you would soon discover, that the DMA channel's CR does not have the enable bit set.
> //start
> DMA2_Stream0->CR |= (1 << DMA_SxCR_EN);
is incorrect, should be
//start
DMA2_Stream0->CR |= (1 << DMA_SxCR_EN_Pos);
As conversions were ongoing but DMA was not there to pick the data, ADC overrun and stopped (btw. for that reason you want to enable DMA before starting ADC).
