STM32F4 ADC multiple channel read using Interrupt WITHOUT DMA
‎2022-02-12 7:04 AM
I want to scan 14 channels of adc1 in scan mode using interrupt. I need it to be with interrupt not DMA and I know how to use DMA so please don't tell use DMA! :D
The problem is that HAL_ADC_ConvCpltCallback runs only once! I will attach my code here. any ideas and help is really appreciated.
my adc init is:
* @brief ADC1 Initialization Function
* @param None
* @retval None
static void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ENABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 14;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_144CYCLES;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = 2;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_2;
sConfig.Rank = 3;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_3;
sConfig.Rank = 4;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = 5;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_5;
sConfig.Rank = 6;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_6;
sConfig.Rank = 7;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_7;
sConfig.Rank = 8;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_8;
sConfig.Rank = 9;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_9;
sConfig.Rank = 10;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_10;
sConfig.Rank = 11;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_11;
sConfig.Rank = 12;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_14;
sConfig.Rank = 13;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_15;
sConfig.Rank = 14;
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
* Enable DMA controller clock
static void MX_DMA_Init(void)
/* DMA controller clock enable */
__HAL_RCC_DMA2_CLK_ENABLE();
/* DMA interrupt init */
/* DMA2_Stream0_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
* @brief ADC MSP Initialization
* This function configures the hardware resources used in this example
* @param hadc: ADC handle pointer
* @retval None
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc)
if(hadc->Instance==ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 */
/* USER CODE END ADC1_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_ADC1_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/**ADC1 GPIO Configuration
PC0 ------> ADC1_IN10
PC1 ------> ADC1_IN11
PA0-WKUP ------> ADC1_IN0
PA1 ------> ADC1_IN1
PA2 ------> ADC1_IN2
PA3 ------> ADC1_IN3
PA4 ------> ADC1_IN4
PA5 ------> ADC1_IN5
PA6 ------> ADC1_IN6
PA7 ------> ADC1_IN7
PC4 ------> ADC1_IN14
PC5 ------> ADC1_IN15
PB0 ------> ADC1_IN8
PB1 ------> ADC1_IN9
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7;
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1;
/* ADC1 interrupt Init */
HAL_NVIC_SetPriority(ADC_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(ADC_IRQn);
/* USER CODE BEGIN ADC1_MspInit 1 */
/* USER CODE END ADC1_MspInit 1 */
* @brief ADC MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* hadc)
/* USER CODE BEGIN ADC1_MspDeInit 0 */
/* USER CODE END ADC1_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_ADC1_CLK_DISABLE();
HAL_GPIO_DeInit(GPIOC, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5);
HAL_GPIO_DeInit(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3
|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7);
HAL_GPIO_DeInit(GPIOB, GPIO_PIN_0|GPIO_PIN_1);
/* ADC1 interrupt DeInit */
HAL_NVIC_DisableIRQ(ADC_IRQn);
/* USER CODE BEGIN ADC1_MspDeInit 1 */
/* USER CODE END ADC1_MspDeInit 1 */
my callback is :
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
internal_ADC1[adc_index] = HAL_ADC_GetValue(hadc);
if (adc_index < 12)
adc_val[adc_index] = (float)(internal_ADC1[adc_index] * 5.14) / 4095.00;
else if (adc_index == 12)
adc_val[adc_index] = (float)(internal_ADC1[adc_index] * 36.3) / 4095.00;
else if (adc_index == 13)
adc_index++;
if(adc_index == 14)
adc_index = 0;
HAL_GPIO_TogglePin(LED3_GPIO_Port, LED3_Pin);
and I call
HAL_ADC_Start_IT(&hadc1);
only once before while(1).
as I configured the adc in scan mode and continuous mode, I expect that at least I jump to my ISR 14 times but on debug it shows that it calls only once.
thanks in advance.
ADC
STM32F4 Series
‎2022-02-12 2:12 PM
well 2 if check + one addition + on multiply + one division takes less than 50 cpu cycles which at 72MHz it takes about 700 ns. plus HAL_ADC_GetValue(hadc). it shouldn't be a problem I think. but I'll debug and check the exact cycles that it takes.
‎2022-02-12 2:39 PM
Just note that HAL_ADC_ConvCpltCallback is not the IRQ handler, but rather is called somewhere within the HAL chain. Also "51.4" is a double, not a float, and operations on doubles are much slower due to no hardware support.
‎2022-02-12 2:44 PM
Consider the following code:
volatile uint16_t value = 1023;
volatile float x = (float) (value * 5.14) / 4095.00;
volatile float y = value * (5.14f / 4095.0f);
The calculation of x takes ~164 cycles while the calculation of y takes only ~12.
‎2022-02-12 3:43 PM
These calculations are of a double float type. As F4 has only single float FPU, the code is compiled with software implementation. Actually it's even worse - the multiplication is done as double, then you convert the result to float, then it is converted back to double, the division is done as double and then the result is converted to the type of adc_val element. The whole line definitely takes several hundreds of CPU cycles.
Also, when scaling floating point types by a constant value, there is no sense in doing more than one multiply operation. And dividing with 4095 is just wrong and distorts the data scale. The ADC range is 4096 possible values!
A correct implementation for single float with a single multiplication is this:
adc_val[adc_index] = internal_ADC1[adc_index] * (float)(5.14 / 4096);
And for this task the HAL/Cube broken bloatware is totally inappropriate...
‎2022-02-12 9:09 PM
Use 32 bit in fractional mode for each channel, as adc is 16 bit only. If you compute ins decimal to see the result, use int adcval_x100 to keep thing easy and not using float. Do the conversions out of the interrupt. Mayne start with single conversion first. As it is mostly done in 8 bit mcu
‎2022-02-14 10:13 AM
There is multiple options.
a) Use ADC with sequencer with DMA to scan all channels in easy way. - you don't want this (why ?)
b) Use ADC with sequencer and read out conversion results in IRQ routine. That is risky way because you have to guarantee that your program will read data in time. Other IRQ routines can delay ADC IRQ routine. You rutine can be slow due some data processing. And many another possible issues waits for you if you use this way. Disscussed above.
c) Use ADC with sequencer and trigger each conversion by timer. You have to manage same problems asi n b) variant, but you have better control of conversion period and you can make it sufficiently long.
d) Use ADC without sequencer. In each ADC IRQ routine read conversion result, change input channel and start new conversion.
‎2023-07-22 10:32 AM
- « Previous
- 1
- 2
- Next »
