2023-03-13 3:34 PM
hello i am working with i2c i used register for coding i2c but when i configure AFRH register i cant upload my code to my board i have target not responding error then i tried hal library but nothing changed
2023-03-13 7:55 PM
This is because PA14 is used by the debugger (SWCLK). Don't touch it if you download the program over the debugger.
2023-03-13 7:55 PM
2023-03-14 2:45 AM
hi thank you so much
