Stm32F0 TIM16 PWM not continuous
hdemi.1
0693W00000Y90r4QAB.pngPwm is not continuous My clock freq 20mhz
Where am i doing wrong ?
void PWMparamc(uint32_t PWM_freq, uint8_t duty){
  PWMparam.period = (SystemCoreClock / PWM_freq) - 1;
  //PWMparam.prescaler = (SystemCoreClock / TimerTickFreq )  ;
  temp_duty = ((float)duty)/100 ;
  PWMparam.newDuty = ((PWMparam.period+1)*(temp_duty)) -1 ;
  PWMparam.pulse = PWMparam.newDuty ;
void PWM_TIMER_Config(){
PWMparamc(250000,50);
TIM_TimeBaseInitTypeDef TIM_InitStruct;
 TIM_OCInitTypeDef TIM_OCInitStruct; // OC: Output Channel
 NVIC_InitTypeDef NVIC_InitStructure ;
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM16, ENABLE);
 PWM_GPIO_Config();
TIM_InitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_InitStruct.TIM_CounterMode = TIM_CounterMode_Up;
TIM_InitStruct.TIM_Prescaler = 0 ;
TIM_InitStruct.TIM_Period = PWMparam.period ;
TIM_InitStruct.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(PingTIMER, &TIM_InitStruct);
// Timer PWM Konfigurasyonu
TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStruct.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStruct.TIM_OCNPolarity = TIM_OCNPolarity_High ;
TIM_OCInitStruct.TIM_OutputNState = TIM_OutputNState_Enable ;
TIM_OCInitStruct.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OCInitStruct.TIM_OCIdleState = TIM_OCIdleState_Set ;
TIM_OCInitStruct.TIM_Pulse = PWMparam.pulse;
TIM_OC1PreloadConfig(TIM16,TIM_OCPreload_Enable);
 TIM_CtrlPWMOutputs(TIM16,ENABLE);
TIM_OC1Init(TIM16, &TIM_OCInitStruct);
 TIM_Cmd(TIM16,ENABLE);
3 REPLIES 3
gbm
Principal
How many times do you cal this function in your code? Should be called only once during init.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
hdemi.1
1 time
AScha.3
Chief III
try with lower pwm frequ. or check with a scope (to avoid sampling problem)
and show measurement.
